purplechimney's avatar
purplechimney
my points weren't doubled when I was in a 2x boost
Today I took a bike from a 2point station and returned to a 2 point station, when I was in 2x boost. And I only received 4 total points for it. Shoudn't I have received 8?  And is there not any way t...
    When the boost is active we double the points on the map rather than do the calculation post ride, so what you see is still what you get.
    You can tell that the points have doubled because when you are in 2x the lowest points on the map are 2 and in 3x, the lowest points are 3 (also, you'll see that scores only turn pink to signify they're high value at 6 points when you're in 2x boost or 9 points when you're in 3x boost).
