Hi, TaichiKen, thank you for visiting the community to report the issues you're having with your app and with contacting support. I can understand this might have been frustrating, and I wanted to look into what happened more deeply to make sure this wasn't a signal of a larger issue.
The Bike Angels Team wasn't able to replicate the issue you're experiencing with not seeing your points on the map. Of course, there is always the chance that the feature was toggled off in your app settings. If that's not the case, our findings are pointing to connectivity issues with your device. We were able to find your support contacts, and it appears they were connecting with our systems and agents were connecting with some of those calls. We're thinking connectivity issues are the root cause of these experiences.
That said, I sincerely apologize this happened today! I would suggest you log out, delete and reinstall your app, and ensure your device is updated to the newest version. I'd also make sure the wifi was turned off to make sure it's not trying to connect to nearby weak signals. 👼
- 3 years ago
- 19 days ago
- 8 days ago
- 15 days ago
- 21 days ago
