Zubin's avatar
Zubin
Banked Points with Membership Expiry
Hi there
With the new rewards system in place, do points expire if my citibike membership expires?
If no, can I use the points to buy a membership?
Thanks all
  • They shouldn't expire, but you can't access any bike angels features (including the points bank) unless you have an active membership, so you should make sure you keep extending your membership using saved up points in your bank month even if you are away for a bit.
1 Reply
