Gator
3 years agoResourceful Rider
3X Streak Ended on a Positive Ride
I had a 3X streak going that was ENDED by a ride in which I earned 9 points: I picked up from a neutral station and returned to a station that had 9 return points. In the past I believe that all pos...
- 3 years ago
Hey Gator ! Neutral rides shouldn't affect streaks and negative pickup and dropoff locations will immediately end an active streak, just like you mentioned. If there was an issue with a specific streak from your rides on Friday, I'd recommend contacting Support, here, to ask them to take a peak at what happened in case there were any issues.
